Thank you. There is no visible problem, was just worried as it’s a brand new laptop. Thanks for your help.if theres no visible problem
wouldnt worry about it
AI is pretty amazing
but its still a very long way off
from putting all of us giving pc help and advice
out of a job![]()
yeah at the end of the dayThank you. There is no visible problem, was just worried as it’s a brand new laptop. Thanks for your help.
Hehe yes. It seems very over cautious, AI. But it helps me in a way too as I can seek support without annoying you all. But sometimes its responses do seem very over cautious. Cheers!
Yep, it said DDR4 but I’m pretty sure DDR5 is better!yeah at the end of the day
AI is just repeating something it scraped from
the internet
its not thinking for itself (not yet anyway)
try asking it to list you components to build a pc
some of its recommendations are just totally wrong
This is a different laptop?Why do you keep insisting to return a laptop for little things like this? This isn't the first time you have wanted to return this device. IF you want to return it then do so. You don't need approval from someone over a forum.
Brand new laptop 'Windows was not properly shut down'
I've had a new Lenovo IdeaPad laptop for about a week and today the start up time is a bit longer than normal and I keep seeing after most boots today 'Windows was not properly shut down' in reliability history. I remember this happening on Windows 11 on another Lenovo device last year that I...forums.overclockers.co.uk
And I’m not looking for approval, I’m asking for help regarding the reliability history error and whether it should concern me. I hate posting for help now. This laptop cost me £2k and I wasn’t sure whether an error in reliability history on a new laptop is normal or not. That’s all. Sorry, I’ll go now. Can someone delete my thread?
This thread said Legion Pro 5 and the other thread said IdeaPad. I bought a new gaming laptop and a new work laptop.The thread doesn't need deleting, like you said it's a different laptop.
It looks like you asking questions about the same device, not that it matters though.
