Please Explain Satellite Bearings (& Bearings in General)
19 Jan 2003
Bristol, UK
Embarrassingly I don't really understand how bearings work, espescially when relating to geostationary Sat's.
Let's use 28.2E (Astra 2 cluster) as an example. That's where all your Sky dishes will be pointing.
What does this actually mean, 28.2 degrees PAST East? Therefore 90+28.2=118.2degrees?
If a satellite is at 5W does that mean 5degrees past W? 275degrees?
What if a satellite is dead on smack North, how is it then expressed?
Also, with regards to geostationary satellites how come Astra 2D is always at 28.2E? If I move east across the continent surely this should decrease? How come over in Greece it's still 28.2E?
I understand why the angle of elevation of the dish changes as you move closer/further from the actual sat.
I hope someone here will be able to enlighten me!
Satellite positions are relative to the prime meridean, being 0 degrees.
Further east/west you are of 0 you take that into account when aiming I presume.
If you wanted to point your dish at Hotbird you would take into account your longitude of your location.
For example if your lived in Macclesfield, your longitude would be 2.117° W. You would add that to the longitude of the satellite.
Hotbird at 13E would actually be 15.117° E from you.
Don't quote me on that though. I am still missing an odd satellite on my receiver which I can't find.
You wouldn't be able to see a satellite that's 180 degrees from you due to the curvature of the earth.
Same applies to locations that are too far north/south.
