Please gimme some help on a new monitor.
26 Dec 2015
Hi guys,
I currently have an old Samsung Syncmaster 2693HM monitor. I am looking to upgrade it to either a 34" or 40".
The problem I have is this: I do not like these new Ultra Wide screens. I have looked on Overclockers and (cough Scan cough) but the monitors seem to be long and thin where I am used to a more square screen.
I have looked at these 2 monitors:
https://www.overclockers.co.uk/phil...z-widescreen-led-monitor-black-mo-022-ph.html
https://www.overclockers.co.uk/iiya...z-widescreen-led-monitor-black-mo-130-iy.html
But without seeing them in the flesh I cannot tell if these 2 are the newer long Ultra Wide thin screens.
I would also consider a good 34 inch.
Does anyone have any ideas on a good monitor that is not Ultra Wide with a budget of no more than £600? Graphics card is an EVGA Superclocked GTX 970.
Many Thanks
Paul
Those are just normal 16:9 widescreen monitors. It sounds like you want to be avoiding screens that are 3840x1440 or 2560x1080 as those are the ultra wide screens.
edit: A 970 really isn't going to cut it at 4k if you like playing the newest games. You really should research how well your preferred games perform before pulling the trigger.
