Permabanned
- 3 Nov 2015
Hi 8pack I am hoping you can shed some light on why I can't overclock my 5960x in the bios. My system specs are -
i7 5960x
gigabyte gaming 7 X99
16gb ddr4 Avexir 2666
980ti
SSD's only
Corsair AIO cooler gentle typhoons
Now the problem I get is I can't change any settings in my bios to do with overclocking other than CPU Upgrade, which is clearly not what I should be using.
Setting XMP alone doesn't boot, setting XMP with a core voltage of upto 1.3v or more doesn't boot either.
I have tried settings such as -
Core clock - 35 - 43 ( all the way upto 1.35v No boot )
SA (0.025 - 0.075) no boot
Uncore (auto/33-38, no boot)
VCCIN (1.8-1.9,no boot)
Leaving all settings on default apart from XMP doesn't boot.
I have ran memtest and tested the pc with no faults found, so I am really lost here, not sure what I am doing wrong. I was hoping someone with your expertise may have an idea so I don't have to use stock speeds or CPU Upgrade.
Also to add I installed the gigabyte overclock software to see if that works, and when it sets XMP and restarts the PC wont boot. So I have to remove XMP and boot up with stock again. I might try and reseat the memory and remove the chip for a minute. Really odd this.
Thanks David
i7 5960x
980ti
SSD's only
Thanks David
