Please help a friend choose an ISP...
18 Oct 2002
Maidenhead
Hi all,
Please can you help my friend to find an ISP. They want the best service available for a max of £20 a month.
The following services are available in your location:
BT Wholesale ADSL
BT Wholesale ADSL Max
BT Wholesale SDSL
Easynet LLU
Tiscali LLU
Now Wireless
You are connected to the Windsor telephone exchange.
ADSL is available in your area
Your exchange is also enabled for ADSL Max services
According to BT Wholesale, your line should be able to support a 4Mbps or greater ADSL connection via ADSL Max.
Standard ADSL RAG results:
You can receive 2Mbps ADSL
You can receive 1Mbps ADSL
You can receive 512Kbps ADSL
You can receive 256Kbps ADSL
You are approximately 2.17km from the exchange (straight line distance).
Who would you recommend?
Thanks
A[L]C
