I'd always dismissed watercooling due to cost but after buy a Lian Li PC-011 case and struggling to find a decent air cooler that fits i'm now seriously considering building a custom loop (just CPU for now).
The first thing to mention is that pump noise a chief concern of mine as my PC sits only 2-3 feet away. I've bought and returned 4 AIO's over the years due the noise of the pumps so i'm hoping a custom loop pump will be quieter.
The other thing is i'm looking to make this as cost effective as possible without cheaping out on crappy parts.
After doing some reading on these forums i've settled on the following components (i am of course open the suggestions).
XPX CPU waterblock - £50
NexXxoS ST30 full copper 360mm radiator - £70
EISBECHER D5 250MM ACETAL RESERVOIR INCL. 1X ALPHACOOL EISPUMPE VPP755 - £110
Mayhems soft tubing - £2.50
Mayhems X1 CLEAR PREMIXED WATERCOOLING FLUID 1L - £7
Besides advice on the above parts i'd really like help in choosing the correct fittings as i dont really know where to start or what i'll actually need. I've seen a lot of people mention Barrow Fittings as a good cost vs quality option.
Are there any other things i'll need (drain ports, gaskets, mounting brackets etc etc)?
Any help would be most appreciated.
I was looking to buy one, just a couple of threads on here about individual ones being poor finish.
