Please help ASAP :)
18 Jan 2004
Sunny Scotland
Okay bought lian li v1100 plus, but when I put in the psu it doesnt fit :confused: sticks out the back and I pushed it in as far as possible, this is obviously a massive issue if I have done this correct, included is a pic below.
any ideas ? is this normal ?
Is it possible to drill out the rivets on the wall behind it and move it back the distance the psu is sticking out then re-rivet it into its new position? If not you will have to cut the wall so that the psu will fit through it.
just checked and the plate at the back has screws holding it at the top but appears to be rivits at the bottom so will take the screws out and then get my m8 to push the rivits out :)
You sure it's riveted from the bottom? It should be screwed from underneath.
