Hi there guys. I recently bought my new computer as detailed in my sig. I decided to use my old IDE HDD as it had served me well and wasn't causing me any problems, So I installed windows on it (legit copy) and all drivers etc. All was good....or so I thought. I turned the computer off at night, then when I went to turn it back on in the morning it didn't want to work. I got an error message saying
"Windows could not start because the following file is missing or corrupt: <Windows root>\System32\Ntoskrnl.exe
Please re-install a copy of the above file. "
So I tried using the recovery console and that still didnt make a difference. so I then formatted the HDD again, and same problem, I could use the computer fine, and it would restart fine when installing drivers etc. Then when I turn the computer off at night and back on in the morning I get the same error message in the morning......This is really starting to annoy me.
I just don't know what the problem could be? A mate of mine thinks it might be the harddrive on the fritz....What do you guys think? I have also tried to different copies both legit of windows xp and still I get the same problem...I tried an old hitachi deskstar HDD, and after it loaded the setup files, and then restarts to start installing windows, I get the error message "A disk read error occured Press CTRL + ALT + DEL to restart" So I think that HDD is gone as well. Please help me before I go insane....
Should I just order an SATA HDD and get it over and done with?
Thanks in advance....Sorry for the long post
Kiz
Kiz
