Alright, I bricked my Gigabyte windforce R9 290 by flashing faulty bios on to it, even better, i managed to brick the second bios (I am very smart).
Also while switching the switch to use another bios i managed to brake the switch and it came out ...
PC doesn't POST with R9 290 in it (classic black screen), only posts and works fine when I use Intel's iGPU (which i cant game on).
And right now i cant flash the normal BIOS on because system wont even recognize the card because there is no bios, I also get "adapter not found" when trying to get info or flash the bios in the DOS using AtiFlash.
I've found the "short 1+8 pin on the bios chip" method but it wont work
, also tried shorting 4th and 5th pin
(1st YT comment) but that also doesnt work.
My best guess is that i didnt make good contacts on the pins or the BIOS switch on the card is ****** and doesnt make good contact as well (I managed to put it in somehow, but it doesnt feel right).
Here are all the pics, might help.
https://imgur.com/a/JlcAsE5
