- 9 Apr 2014
Hi all,
I really need your help with a upgrade dilemma.
I want to upgrade my Gigabyte 7950 OC card.
The main reason is for purchasing a new monitor which I plan to get in June/July. I currently use a 22" Samsung SM-2232BW which runs at 1,680 x 1,050.
This is something I want to upgrade but want a better graphics card first.
I want to order this today but stuck between the AMD R9 290 and the Nvidia GTX 280. These are my choices:
Gigabyte GeForce GTX 780 WindForce 3x OC @ £360 at competitor
or
Sapphire Radeon R9 290 Tri-X OC @ £325 at competitor
Is the 780 worth the extra?
Both seem good, although some say they have driver issues with the AMD and black screens. But hen again the R9 290 is newer.
The last sticking point is that it needs to fit in my case which is a Fractal Design Define R4. There is only just under an inch between my current card and HDD caddy. This is a major concern about the Sapphire as it is known for being longer.
I would like to order today.
Hope you can help.
i3770K with 16GB DDR3 RAM.
or
Hope you can help.
