Hello all I need your expertise
Could you please check this for me and advise me if anything needs changing, for something better or if something is no good etc
Case= Silverstone tj07
Processor= Intel core i7-2600k Want to o/c
Motherboard= Asrock Z68 Extreme 7 Gen 3
Graphics Card= Palit GeForce Gtx 580 3072mb and will get another one at a later date
Power Supply= Corsair Professional Series AX750 High Performance 750W Modular '80 Plus Gold' Will this be ok to run the two Graphic Cards?
Hard Drive= Corsair Force Series 3 120GB SATA 6Gb/s Solid State Drive Again will get more at a later date
Ram= Corsair Vengeance 16GB (4x4GB) DDR3 PC3-12800C9 1600MHz Dual/Quad Channel Kit
Optic Drive= LG BH10LS38 10x BluRay-RW / 16 x DVD±RW Lightscribe Drive - Black
CPU WaterBlock= XSPC RayStorm CPU WaterBlock (Intel) **2011 Compatible**
Graphics WaterBlock= EK FC580 GTX+ Full Cover Waterblock - Nickel Plexi **EN Nickel Plating**
Graphics backplate= EK-FC580 GTX Backplate - Black
Reservoir= EK Multioption Reservoir X2 250 Advanced
Radiator= XSPC EX480 120mm Radiator - Black
Pump= OcUK D5 Vario Pump & EK D5 X-Top V2 Value Combo
And could you suggest some good fans and anything else you think i may need
Thank you for your time
Steve
Steve
