Hi guys, I'm rather hoping you can help me confirm my diagnosis that I have a faulty RAM module
Firstly, the key specs:
Intel Core i7 920 D0
Gigabyte EX58-UD5
Corsair XMS3 DDR3 6GB - TR3X6G1600C9
PowerColor ATi HD 3870
OCZ StealthXStream 500W
I should state absolutely everything was at stock when fault testing was done.
Ok, so the rig was only built on the 26th as the bulk of the components were Christmas presents, including the memory. Over the last 4 days, I've mainly been building up the OS, getting things to my liking. All this time however, I can't say I've been entirely happy with the way things were running. This was just a gutt thing however, nothing scientific in any way. A couple of freezes, nothing too abnormal.
Last night however, I was attempting to unarchive a couple of files stored across multiple archive parts. I couldn't get the files to extract properly. I was getting consistent CRC errors. I fired up QuickPAR, thinking I had a damaged part, however it advised all parts were complete and undamaged. Confused, I copied the files to a laptop. The files then extracted without any problems what so ever.
Now worried about system stability, I fired up IntelBurnTest and LinX for the first time since building the rig. They both fail within a few minutes. With everything at stock and temperatures well within acceptable ranges, I Googled around and found suggestions of memory problems. I booted the latest version of MemTest86+ and let it run. Within half an hour, I was getting errors at one memory address. I ran the test a few times and every time got errors at this one address. Sometimes faster than others.
This morning I tested each stick individually. Letting the test run for 3 full passes, the first two sticks passed without a single fault. Within minutes of testing the third stick, I had errors and all at the same address. I replaced all three sticks and booted into MemTest86+ again. This time I got a full run before the same error address appeared again.
I should also add that I have also set the memory to run using the Intel Memory Profile, allowing the memory to run at full speed, timings and voltage. The errors still appear, seemingly at only the one address on the one stick.
I know that was a very long read, so to those who took the time you have my thanks
. Can we say the general concencious is I have a dead stick of RAM?
Thanks for any help!
Gigabyte EX58-UD5
