Please Help - Dell S2419HGF 144hz refresh rate question?!
7 Jan 2006
South Wales
Hi,
I'm looking for a monitor to compliment my new budget gaming build, see here;
https://forums.overclockers.co.uk/t...-in-9-years-budget-ryzen-2600-build.18860499/
I've narrowed it down to the following Dell S2419HGF, as it appears to meet my needs. 1080, 144hz, 1ms and from a reputable brand. £180.
On the retailers page I'm hoping to purchase it from (and other retailers other than dell) it lists the following;
Frequency range - Vertical: 56 - 76 Hz
- Horizontal: 30 - 83 kHz
On Dell's site;
Frequency range - Vertical Refresh Rate - 40 - 144 Hz
- Horizontal Refresh Rate - 30 - 140 kHz
What's going on here, why are the numbers different? Is it actually a 144hz monitor or is Dell pulling a fast one :confused:
Any help would be appreciated before I click buy.
Thanks
Hi
It is actually a 120hz panel with a factory overclock to 144hz which you enable in the monitors menu system, so yeah it will do 144hz with the overclock enabled and being a Dell it should be good quality and have good support.
Peahead, thank you for the response, much appreciated.
Hi
That's interesting. Although, 120hz still doesn't correlate to the frequency range listed on the retailers website? So I'm still confused.
