Hey, I'm guessing this is a gfx card problem but I don't really know so put it here.
Now and then, these yellow lines (as shown on picture) begin to appear at equal intervals along the taskbar. It usually starts with them going just past the quicklinks bar (with winamp, firefox etc on in mine as seen in shot).
The artefacts like this only seem to happen on the start bar, but sometimes a little one can be seen on an icon on the desktop.
eg:
The only other artefact I saw was on the google homepage the "web" part next to images was pink and bold
It doesn't seem related to overclocking or temperature as I actually underclocked the card because I doubted my pc could actually use the full extent of it and it's an agp4x board anyway.
The temperature is always aroung 48 for the chip edge and 45 for chip surface so that can't be too hot.
Another thing that happens since this started is sometimes the computer will just stop, with the last frame still showing.
Can't find anything in event viewer.
Another thing, I'm on it now and it's fine. 1280x1024 @ 75hz.
System:
Athlon 1800+ (underclocked to 1.1 as my system doesn't like being over 1.2 even though it should
Leadtek Winfast A280LE TDH MyVIVO (GF4 TI 4200) @208/462
256mb ram
WinXP Pro
SB Live 5.1
EMU 0404.
Cheers.
Also, one time it happened (only once after it hung, pressing restart, the bios had letters not shown eg: "as s" instead of asus.. on the black and white bit.
Anything that will solve this? Thanks.
George.
As a side note, leadtek really need to murder the guy that did the ui for their "winfox" overclocking/monitoring program.. it's horrendous.. you have to hover over every icon for 3secs to find out what it's for(no labels) and it's all in disgusting colours
Thanks.
George.
edit; also, where's the mm incase the gfx is broken and I need to find a cheap old agp card? I couldn't find it.
eg:
System:
256mb ram
WinXP Pro
SB Live 5.1
EMU 0404.
Cheers.
George.
Thanks.
George.
