- 17 Apr 2006
- 3rd rock...
Hey guys
Please help!
As all you lot who play MS Flight Sim know the flight plans are stored as .FLT files in the C:\Documents and Settings\Your Name\My Documents\Flight Simulator Files location.
So to load a flight; rather than start the sim and select the plan from there I dive right into the Flight Simulator Files folder, double-click the plan and off we go.
I had set Windows to associate all .FLT extensions with FS9.EXE but since yesterday its gone a bit wierd. The associations with .FLT files have reset themselves to open with Notepad
So I went through the hoops of trying to get Windows to associate (open with) .FLT with FS9.EXE but it just wont work. I arrive back at the "Open With" window again with nothing done. XP just refuses to do it.
Can you help, some kinda registry thingy perhaps? Thanx!!
Please help!
After I've browsed to and chosen the fs9.exe it does not appear on the Open With list in that dialog window. Its as if nothing happened!
