- 30 Sep 2009
- Beccles, Suffolk
Hello,
I have a Sound Blaster Z and currently a pair of AKG 550's. I would like to get a pair of Beyerdynamic DT880's or something of similar quality. There is an 80, 250 and 600ohm version. The sound blaster says it will drive 600ohm headphones however from reading through a lot of forums, the general consensus is that it doesn't do it very well. So with a budget of say 150 for cans i.e (Beyerdynamic DT880 250ohm version) and 50-100 for a desktop AMP. What are the best amp's that i should be looking at and what connection should i be using from the sound card to the amp (optical or 3.5mm). I am a complete amateur at this and am driving myself mad trying to work it out.
Thank you for any help you can give
