- 20 Jul 2011
Hi there,
Recently brought a PC setup from here and built it myself. All was fine for the first 3 weeks - had 2 crashes but I put that down to teething problems.
Anyway, halfway though a movie today my pc got the blue screen of death and now wont boot up at all.
I have tried everything and I dont know why its not working - it could be a memory problem as the light is on the memOK button ( which wasnt happing before all this ) but whatever I try it just keeps resetting, then telling me to check bios settings ( which i have not changed ) then crashing before windows loads up on the times it has managed to get that far!
Is it a problem with the motherboard? I have only heard bad things about it ( a Asus P8P67-M ) nothing has changed between yesturday when it worked perfect to today where it doesnt get past bios screen if it even gets that far!. I really dont get it and have tried everything I have found online to try to correct the situation.
My specs are as follows :
Asus P8P67-M Intel P67 (Socket 1155) DDR3 MicroATX Motherboard - (Sandybridge) ** B3 REVISION **
Kingston HyperX Blu 8GB (2x4GB) DDR3 PC3-10666C9 1333MHz Dual Channel Kit
Intel Core i7-2600K 3.40GHz
Crucial RealSSD M4 64GB 2.5" SATA 6Gb/s Solid State Hard Drive
OcUK GeForce GTX 460 OC 1024MB GDDR5 PCI-Express Graphics Card
Cooler Master GX 650W '80 Plus' Power Supply
LG GH22NS70 22x DVD±RW SATA ReWriter
Microsoft Windows 7 Bundle - Professional 64 Bit
in a silverstone case with no overclocking ( as I could not find the voltage settings in the bios so left it be )
Thank you in advance for any help. I really dont want to return anything but I dont know why this is happening - everything worked and showed up in windows perfect, now nothing. I am losing whats left of my hair over this, please help before its all gone
