Ordered the valve but was in discussion with a few others in another thread and the valve is confusing me with fittings needed etc.
Anyway I managed to drain it, just did as you said and held the waterblock higher then the tubes and cut one at a time catching the coolant in the jug. Of course I removed Motherboard and PSU completely out the case, and shook it plenty to get all coolant out.
The clips funny enough are reusable as you just prize them open again with a knife or something, so did not need to order more but least I will have some spare.
I got Mayhems Ultra Pure H20 5ltr which if I recall won't need changing for 3-4 years so hopefully I won't need to drain it again in that time. Thankfully I bought 5 liters of the stuff and not 1 as I kind of suspected something might go wrong somewhere.
Cheers all for your help today really appreciate
