I really need some solid advice on this one before I see how far I can get with a Vista refund! I can't find any rational explanation for the problems I'm experiencing. Here's a quick summary of the main problem that's been driving me nuts for the last week or two:
NIC drivers are updated and RAM tested. I'm running out of ideas. As if this wasn't weird enough, I encountered a new problem today. I can't play donwloaded .mov film trailers. Quicktime crashes out with a "buffer overrun" message. BUT, if I copy the same file to a shared network drive on the XP Pro box, I can play it from there (on the Vista box, opening the file from the shared drive)!!!! It won't play from any directory on the Vista machine. The .mov file on the Vista box and it's copy on the XP Pro box have the same MD5 checksum value. What the hell is going on???I'm having the weirdest problem with Vista. After saving image files (tried as jpegs and bmps so far) from any application (Adobe CS2, Canon DPP), I move the images across the LAN to a shared folder on an XP Pro machine. When I reboot the XP Pro machine, the images appear corrupt - no embedded preview on some of them and none of them will open. Weirdly, if copy the folder out of the shared directory and onto the desktop of the XP Pro machine and then reboot, those files appear to remain undamaged. Existing images in the shared directory also appear unaffected.
I've duplicated this problem copying files to a 2nd XP Pro machine, so the issue would appear to originate with the Vista box. I can't see why it only manifests after a reboot of the XP Pro machine though. All the PCs appear to be free from viruses and/or malware. I'm totally puzzled by this one.
This problem only seems to manifest if I copy the files across from within Vista. For example:
Files saved in shared directory X in Vista. Log into Vista box and copy TO shared directory Y on XP Pro box. Files appear corrupt after reboot of XP Pro box.
Files saved in shared directory X in Vista. Log into XP Pro box and copy FROM shared directory X on Vista box into shared directory Y on XP Pro box. Files retain integrity. So the origin and destination directories remain the same, and only the machine performing the operation changes. When it's the Vista machine, the files are somehow corrupted.
