28 Oct 2013 at 17:43 #1 hitman hitman Associate Joined 7 Oct 2009 Posts 498 http://www.overclockers.co.uk/showproduct.php?prodid=MY-290-CS&groupid=701&catid=8&subcat=1517
28 Oct 2013 at 22:52 #2 Frozennova Frozennova Man of Honour Joined 13 Nov 2009 Posts 11,674 Location Northampton Will be perfectly fine. AMD systems are generally pretty difficult to get running properly with anything above 1600mhz ram.
29 Oct 2013 at 06:43 #3 hitman hitman Associate OP Joined 7 Oct 2009 Posts 498 Cheers for the reply Is the low profile version listed on OC exactly the same except for the profile?
29 Oct 2013 at 09:40 #4 Frozennova Frozennova Man of Honour Joined 13 Nov 2009 Posts 11,674 Location Northampton These ones? http://www.overclockers.co.uk/showproduct.php?prodid=MY-307-CS&groupid=701&catid=8&subcat=1517 If so yes they're both 1600mhz 9-9-9-24 If you're looking for any more performance try and find a Cas8 1600mhz kit.
29 Oct 2013 at 11:15 #5 hitman hitman Associate OP Joined 7 Oct 2009 Posts 498 yes they're the ones - was thinking about them in case space was ever an issue in the future. I'll have a look for some cas8 1600mhz kit.
