- 12 Dec 2007
ok i'm currently building my first custom pc! i've encountered a few problems though and i'm not entirely sure what i need to do!
firstly i can't get my dvd-rw drive to fit! i have a raidmax black ninja case which has black clips on the drive bays! the dvd-rw drive is from a compaq presario sr1909uk and the problem is that when i move the clip it withdraws a metal peg from within the bay but there is one on the other side that doesn't seem to be removable and it's getting in the way! any ideas??
also my 320gb Sata Drive fits in the bay but the clip won't go back in! any idea why? it's firmly seated in there tho so i assume it'll be ok without the clip being closed?
the fans in the case all have the white four pin molex power connectors. on the motherboard it has connectors for system fans but i do not have these connections on the case fans. am i right in thinking that i can leave the connections on the motherboard empty and just connect the fans to the power supply?
i hope i've done all this right lol please help i'm getting stressed out!
