Hi.
I've just got a mint powermac g4 dual 1.25ghz MDD pc and loving it
only problem is, its soooo noisey and I was hoping to use it as a media server/htpc for my hi fi system for now. I've looked at the various websites at replacing the fans etc but what do I replace them with?
I need 1 120mm fan and 2 40mm fans. I recently purchased a silenx fan from OC which is very quiet but doesn't shift enough air and causes the optical fan to kick in and create just as much noise as the original 120mm.
Is there anything that offers a good compromise of shifting air and running quietly.
Thanks
only problem is, its soooo noisey and I was hoping to use it as a media server/htpc for my hi fi system for now. I've looked at the various websites at replacing the fans etc but what do I replace them with?I need 1 120mm fan and 2 40mm fans. I recently purchased a silenx fan from OC which is very quiet but doesn't shift enough air and causes the optical fan to kick in and create just as much noise as the original 120mm.
Thanks
