Please help me before i order the wrong stuff!
23 Jul 2007
Swindon
Well my motherboard croaked it tonight and took the CPU with it! So I need an upgrade urgently! I'll be ordering tonight and have come up with this spec:
All I need is PSU, CPU, CPU FAN, Motherboard. I already have a 2gb kit of ocuk 6400 800mhz ram thats unused, a 320GB SATA HD and 7600gt GPU (i'll upgrade later) and case.
My budget was meant to be £200 for these items but as you can see i'm a little over. Any body got any suggestions before i run it through the till? I will be overclocking!
Thanks!
Looks good to me. I don't know enough about that CPU cooler to attest to its effectiveness though. One similarly-priced one that I have used is the Arctic Cooling Freezer.
That motherboard will probably limit your overclock more than the CPU though.
I think you mis-read I will be over clocking! Thanks so far!
Edit: Ah you were too quick :p
You reckon i should cut back on the cpu and upgrade the board? Can you recommend a good board/CPU combo?
Right this is the final spec, can someone check?
Gigabyte GA_P35C_DS3R (Socket 775) PCI-Express DDR2 & DDR3 Motherboard £64.99
(£76.36) £64.99
(£76.36)
Akasa AK-965 CPU Cooler (Socket LGA775) £10.99
(£12.91) £10.99
(£12.91)
Corsair VX 450W ATX PSU (CMPSU-450VXUK) £36.99
(£43.46) £36.99
(£43.46)
Intel Core 2 Duo E2180 "LGA775 Conroe" 2.00GHz (800FSB) - Retail £46.99
(£55.21) £46.99
(£55.21)
Sub Total : £159.96
Shipping cost assumes delivery to UK Mainland with:
City Link Parcel Next Day (Delivered Mon-Fri)
(This can be changed during checkout) Shipping : £8.95
VAT is being charged at 17.5% VAT : £29.56
Total : £198.47
