- 3 Dec 2012
Hi all,
TLDR version:
Please help me build a new PC using an existing 3070 RTX, ideally in a NZXT H710I case, playing at 3440x1440 on an Alienware AW3420DW. Money not really an issue, but within reason - preference is value for money rather than min/maxing.
Long version:
Some of you may have seen a burst of "activity" from on here... to those who have, apologies for the recent "spam" in some of the threads and even creating my own
I have been living under a rock for the last 4-5 years to some degree and have come to the realisation that I should seriously consider upgrading my nearly 5 year old system.
What's important to note is that there are a few components that are "fixed" and that I would like the PC to built around, to maximize the potential of these components.
First and foremost, I just acquired a "Gigabyte RTX 3070 Vision OC" and an Alienware AW3420DW monitor, so the resolution I game at is 3440x1440.
One component I do not have yet, but would definitely want to have incorporated (unless there are serious reasons not to) is the NZXT H710I case - white, since I am a sucker for the white and black combo and the Vision OC is also white.
Whilst I used to always go with Intel CPUs, I understand that the AMD Ryzen appear to be the better choice these days and that's where my questions start:
I would like to say "money is not really an issue" but within reason, i.e. I don't want to/need to spent the maximum amount of money just to get 1% more performance for example. I am happy to go with Premium options but value for money should be considered.
Thank you so much in advance!
TLDR version:
Long version:
- Is it worth getting the Ryzen 9 5950x over the Ryzen 9 3950x ? Or is the
AMD Ryzen 5 5600X perhaps a wiser choice?
Or which Ryzen would generally be regarded as THE best value for money option?
- Which Motherboard would be the best value for money option for the CPU? ASUS ROG Strix X570-E?
- I assume these days I should go for 32GB of Ram, which type is the "go to" option?
- The whole NVMe tech is totally new to me, so which SSD would you guys recommend, that is also big enough to store most of my games? Do people usually still have 1 SSD for Windows and then one for games?
- Not a fan of liquid coolers at all - unfortunately liquid cooler system in my current PC which I had built by Overclockers had a pump failure and I replaced the cooler with a Scythe Ninja. Unless there was serious progress in Liquid cooling solutions (All in ones ideally) I am a bit put off by them but happy to be educated here!
- PSU - no idea what the current go-to PSU would be and how many Watts are recommended?
- Probably goes without saying but I like it QUIET!
