Please help me choose
29 Jan 2018
Hiya. I am looking at purchasing a new 3080. But I'm really undecided on which option to buy. The price isn't really a factor I just want the best card. So I've found 2 msi cards. Which one is the best
msi nvidia geforce rtx 3080 gaming trio lhr 12gb this is about £789
Or the dearer by about £100 but has less memory
MSI NVIDIA GeForce RTX 3080 10GB SUPRIM X LHR​
Thanks
Yep, it's not just the memory that's different, the 12GB 3080 also has 256 additional cuda(/shader) cores!
(also the 12GB config also necessitates a wider memory bus, hence more bandwidth)
Wow okay. I thought the more expensive one would be the card of choice. Happy days
12gig 3080 is a performance improvement over the 10gig model. Not a huge performance improvement but definitely if it's cheaper than the other models you are looking at, go for it.
