Hey
Ive had my current setup running nicely for a while now. Could you guys please give me some tips for Oc'ing it a bit. Its been soo long since I clocked a systems that I need a few hints
Systems Specs (all at stock):
AMD X2 6000+
MSI K9A Platinum Mobo
2 x 1Gb Corsair Dominator PC2-6400 RAM (might be bumping to 4Gb soon)
2900XT
Vista x64
What settings should I be looking at using to give it a bum and what can I expect to get on air, my old water cooling kit isn't with my at Uni.
Thanks
AMD X2 6000+
2900XT
Vista x64
Thanks
. Just lock pci-e frequency to 100 mhz and make sure mem speed, mem timings, vdimm and vcore is set correctly. That should get you going
