Hi all,
I'd like to upgrade from my LG SK9Y soundbar (for reference this is the most I had ever previously spent on home audio, and in general I've been pretty happy with the sound), but I'd like to get my first ever system with separate speakers, and an AVR.
My girlfriend and I have quite a lot to pay for at the moment (setting up new house), so 2.5k is about the maximum I'd like to spend.
My front room is of medium size, and has a rectangular shape, but it isn't too much longer than it is wide. The TV (LG C9) sits against one of the shorter walls.
I have been looking at a 5.1 system powered by something like the Denon X3700H. I'd also like an atmos effect - if there would be any installation costs I could cover them as long as reasonable
What kind of thing would you recommend? I've mainly been looking at Richer Sounds, as I've liked dealing with them in the past.
The usage will mainly be for movies and gaming, with some (but substantially less) music. I'll be hooking up a next gen console (as soon as I can get my hands on one), not sure if that will make any difference to your recomendations.
I'd like to go new this time, rather than looking at anything used.
Thanks!
Thanks!
