Please help me upgrade my graphics
15 Mar 2012
Santas Grotto
I currently have a 4.8ghz 3930k with 2xGTX460 in SLI running 3 screens.
Screens are 1 x Asus 27 IPS Daul DVI and 2 x VGA 22 inch HP screens
So looking to replace the 460's with something under £700 that is capable of running these 3 screens with their connectors.
Do I need 2 cards, or is this possible with 1 card?
Not fussed if NVidia or AMD
Thanks
Only planning on gaming on the 27 central IPS monitor. Normal processing and day to day is on 3 monitors as extended desktop.
I'm not 100% certain, but I think you can get away with a 7950 as long as you're not gaming with eyefinity, let someone else confirmt his though.
You can always add another one if you feel a single is struggling, but it should be fine with a single 1080 monitor :)
7950 if only gaming on one monitor is plenty and will run all three monitors.
Thanks, I assume it has the right connectors for me. I currently use 3 x DVI for the 3 monitors.
Looking at 7950 cards they have DP which I can run my IPS main monitor on and 2 x DVI which with adapters I have I can run my VGA screens.
I assume these cards are capable of using these connectors at the same time
mmm, this looks right for me
http://www.overclockers.co.uk/showproduct.php?prodid=GX-287-AS&groupid=701&catid=56&subcat=1673
Plug in the 2 smaller displays with a DVI-VGA connectors and the IPS monitor with the DP connector.
It is 3 slots high card. but no intentions of adding in another card.
It is PCI 3 capable, which should be nice with my X79-UP4 board.
Or this if I go higher
http://www.overclockers.co.uk/showproduct.php?prodid=GX-276-AS&groupid=701&catid=56&subcat=938
or this
http://www.overclockers.co.uk/showproduct.php?prodid=GX-303-SP&groupid=701&catid=56&subcat=938
Shame on you Cleec quoting those months old benches!! A 7970 at ~£300 is your best bet for ~60fps at 2560x1440 for full Ultra on BF3. Obviously you might not play this game but I'm just using it as a base for power needs. If you don't play games that are as demanding probably a 7870 or 7950. If you want to go green the 670 is your best bet.
EDIT: Also the 7950 seems to be using boost where the 7970 doesn't (in that review).
I think you're arguing a different case. Nobody's saying the 7950 is better in terms of performance than the 7970, the 7950 is pretty damn close, but costs roughly £50 less, making it better value for money.
Shouldn't you be comparing the GHZ edition since AMD released some kind of bios thing that sets your card at higher clock speeds for free? :)
Seeing as not every 7970 is a ghz edition, i thought it best to just use the reference 7970, i'm trying to be as neutral as possible here:p
As we're trying to compare AMD with AMD, the age of the benches won't matter as both cards had similar performance gains with the latest drivers:)
As for the boost, I was told that all 7950s now come at those speeds and the standard 7950 used in that comparison was a previous, obsolete revision. Please do correct me if I'm wrong :)
