Please help me with this problem
18 Aug 2012
I have a problem its a 775 socket Motherboard Name ECS MCP73VT-PM, onboard graphics works with no problem.
When I have PCI.E graphics card connected it post to bios then after bios its still loading windows with out posting with the graphics card.
it is the Radeon 4870x2
what can the problem be guys I know it is a old motherboard but that is what I got at moment.
It also shows disk check before windows but wont show anything else but bios and then disk check :(
do you have this in your bios as you need to change from pci to pci-e
PCI / PnP Configuration
This page sets up some parameters for devices installed on the PCI bus and those
utilizing the system plug and play capability.
Init Display First PCI Help Item
CMOS Setup Utility - Copyright (C) 1985-2007, American Megatrends, Inc.
PCI / PnP Setup
Enter : Select +/-/: Value F10: Save ESC: Exit
F1:General Help F9: Optimized Defaults
