Please Help need to upgrade my PC badly XD
25 Mar 2006
Ireland
Hi new to forums,
Basically I want/need to upgrade my PC so i can play current gen games I really want to play Elder Scrolls:Oblivion on med-high settings on 1078x768(?) res. These are my specs
Dell dimension 8400
3Ghz P4
512mb Ram
X300 128mb
I know i need to upgrade my Graphics Card I was thinking either a x1800xt for £170,7800gt xfx for £150 or 7900gt for £200. Please tell me if a RAM upgrade is necessary for one of these cards to perform well as i really have a tight budget. If it is could you guys advise me on which type of ram to buy? As its Dell i cannot overclock it please guys any help GREATLY APPRECIATED. I think those prices will rise next week please reply asap thx.
PS. A 480w TrueBlue PSU should suffice?? thx.
You will need more than 512 of ram for these types of games unless you want really choppy gameplay, as I found out, having to pay for postage again to get more ram.
This will help you decide on a card:
(please note the res and AA that it was ran at.)
I would seriously think about getting a gig of ram - I am sure some kind soul who is an expert on p4's willl tell you exactly what type - or even better two gig if you can afford it.
As to graphics card, I would seriously consider a 7900GT or an X1900 to enjoy the most recent games at good speeds - you may get away with 7800/1800 but I would save up a little more if i were you
Thanks Frank greatly appreciated Im thinking of 7900gt ;)
but still need help with the ram seeing as i cannot overclock would i find much difference between value ram and expensive ones?
Also would any ram be compatible with my mobo?
That pc does actually use DDR2.
OcUK have ..
Samsung Original 512MB DDR2 PC5300 667MHz (MY-015-SA)
£41.07*
As for graphics the X1800XT is faster than the 7900GT. the extra ram will also help so get this card to save a bit of money & everything should run fine -
PowerColor ATI Radeon X1800 XT 512MB GDDR3 AVIVO TV-Out/Dual DVI (PCI-Express) - Retail (GX-048-PC)
** Available This Week Only for just £199.95 +VAT. **
edited to add:
As stated below though, you may need new PSU for such a powerfull card.
When you upgrade your graphics, you will probably need a new PSU. Which won't work because you have a dell so you will need a new motherboard, which won't fit because you have a dell so you will need a new case. The heatsink will be dell only most likely so there will that as well...
yeah don't buy a dell :p
the dell 8700 (or 4700) cant quite remember, took standard atx psu's
besides the dell psu's tend to be quite good, can remember using a 6800 ultra in the days.
