Please Help New Rig
26 Mar 2015
Sapphire r9 295x2
i74790K
Kingston hyperx 32GB
Aus Tuf Z97
Corsiar RM series 1000W
Seagate 2tb
Kingston HyperX 240Gb
I am going to buy this rig but before I do I need abit of help at the moment the games I am playing are Minecraft,Skyrim and Dota 2. I run my pc through my tv 1080P HDMI cable.
I want to be able to play Minecraft with 512x512 Texture pack and use shaders and mods. The problem I have is all the review and forums are saying the R9 series performance for Minecraft is really bad because people are only getting around 50-60 fps.
I aslo upload videos to youtube and I record videos using xsplit. Please help me build my dream computer.............
32GB of RAM, 8GB is fine for games.
Not all operating systems will even address that much RAM.
I also dont see a case listed.
The RM1000 is not as good internally as say a Superflower or EVGA G2 PSU.
For the games your playing a 295x is extreme overkill,does minecraft even have Crossfire profiles lolol
Get a a single 290x m8
The ram is mainly for minecraft so i can play with mods as minecraft is more java base and cpu.
The case i am searching for as i want a silent case mid tower
but is the evga and superflow silent??
If you dont have a suitable OS then the system may not even see more than 8 or 16GB of RAM.
The EVGA is made by Superflower, they are bot silent, the Superflower leadex range have an Eco fan mode so doesn't spin up till a certain temperature is reached. Some EVGA have this too, some dont.
The superflower and evga G2 psu's are very quiet, basically they are the same psu as superflower is the oem for the evga units. Sadly, corsair psu's of late arent as good as they once where.
With the optfine mod it alwas crossfire......I looked at the 290x 8gB but I need 246 Skyrim mods and am not sure the 290x would do well with all those mods........
Thanks so much Setter and Stulid I will change to superflower because you both have the same PSU. Do you have any suggestion about the mother board?? because I will never overclock the motherboard
