- 1 Feb 2015
Hi, recently I bought a new motherboard and processor (I'll put their names at the bottom) and it was my first time building a computer so I'm sorry if the solution is as simple as plugging a wire in somewhere, I put everything together, there was no problems yet when I turn my computer on there is a message that comes up on my monitor that's says "DVI" and then "no signal" and just goes into standby mode. I wouldn't have posted this if I didn't really need help, I've relocated the graphics card, help the power button while the power chord is out for 30 seconds still no response, the jumper is on the correct settings, I've tried different inputs with different wire and used my computer with a different monitor and still nothing. I have spent 2-3 days trying to fix this problem and I would appreciate it a lot if someone could help me!
Processor - AMD piledriver FX-8 core
Motherboard - ASrock 990FX extreme
