I have recently updated a few bits and pieces being a newer GPU & CPU to my rig as well as an SSD. The motherboard and ram are a year old and the case, HD, and PSU are all a few years old.
Basically I'm noticing my FPS on BF4 mostly to be dropping to as low as 25-30fps in some situations - Now I'm sure this shouldn't be the case and that the 8350 shouldn't be bottlenecking the gpu that much if at all.
Is it possibly the ram or psu causing these issues? Normally it does keep a steady 70+ fps ( all stats on high not ultra AA off v sync off ) but it is dropping and notably lagging.
The mobo is slightly older so the drivers wouldn't work I had to update the bios myself - could this be an issue? Basically I'm not made of money and this was a real treat on the credit card as I wont be able to go out much the next couple of months so its frustrating me its not working correctly.
I have just switched over to windows 8 pro and I'm still leaning how to use it! (might switch back to 7). I haven't yet changed the power to high performance rather than balanced as I have read this could be an issue? is it ok to leave this on high performance all the time? I know the psu is only a 620 but I was under the impression this would be sufficient. I have also noticed when hitting CTRL+ALT+DEL it does state on performance sockets: 1 Cores: 4 logical processors: 8 now im no expect but surely this should say 8 cores?
Any help would be much appreciated this is getting to me!
Gigabyte GeForce GTX 780 WindForce 3x "GHz Edition" 3072MB GDDR5 PCI-Express Graphics Card
AMD Piledriver FX-8 Eight Core 8350 Black Edition 4.00GHz (Socket AM3+) Processor - Retail
Kingston HyperX 3K SSD 120GB 2.5" SATA 6Gb/s Solid State Drive (SH103S3/120G)
Seagate Barracuda 7200.11 500GB SATA-II 32MB Cache - OEM (ST3500320AS)
Asus M5A78L-M/USB3 AMD 760G (Socket AM3+) DDR3 MicroATX Motherboard
GeIL Black Dragon 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz Dual Channel
Arctic Cooling Freezer 7 Pro Rev 2 CPU Cooler
Antec 900 Nine Hundred Ultimate Gaming Case - Black
Monitor benq 24 xl2411t
I'm at work at the moment not at my personal computer but the psu is a xhcrosshair 620 modular power pack i believe it could be almost two years old. I'm now having to debate selling the card and getting a cheaper card in order to upgrade psu, mobo or ram?!
Thanks again.
Thanks again.
i would strongly recommend that you change it to a full atx board like the gigabyte ud3 rev4 or the asus m5a99x or get a lower powered cpu like the 6300, but even then that micro atx board will not be great.
