Hi
Right ive got me lian li 343b ready for me build which i will be doing tonight/tomoz!
i have the alpha water kit 120.3 so shall i mount pump/res as high as i can?
Radiator in right hand side of case ie p/supply side?
Pipes on rad at top or bottom?
Pump/Rad/Block/respump?
Do i have the fan pulling air out of the case though the rad or into the case though the rad?
Would i bennefit having 3 fans blowing into the rad and 3 fan pulling out of the rad?
Plz help chaps as one i pull my rig apart i have no internet connection and wanna get it right first time!
cheers
cheers
