- 27 Apr 2009
Hi guys, this isn't as tediously vague as it sounds, honest!
My PC has only booted once since I changed the motherboard.
I only have a Macbook Pro at home here, and my Vista system has a freshly formatted hard drive but it doesn't want to play!
On changing the motherboard the PC wouldn't boot so I reformatted the disk using Mac disk utility first to 'free space', then from empty I set it to '1 partition- FAT' and neither of those booted in the PC.
I then used my Win7 PC (isn't at home with me) to reformat the drive to NTFS. Stuck it back in, boot and splash screen, Windows Vista disc in and it started up.
(sorry for the tedious story) I got as far as the Win Vista install screen, choose which disk to install to, wouldn't let me even when I tried deleting the previous partition I created using my other PC and creating a new partition in the Win vista install menu. It was saying something about it having GPT partition, or similar. Never came across that before, I wondered if it was because at one point I formatted the drive on Mac?
Anyway I whipped the drive out again, downloaded Paragon for Mac and reformatted the drive AGAIN to NTFS. Now the PC goes back to not booting again! Doesn't even reach the splash screen, at least it reached the splash when I formatted the drive using my Win PC.
Am I missing something?! I'm pretty sure my hardware is sound as an hour ago I was almost installing windows if it wasn't for this GPT error!
Can anybody shed some light? This is my old off the shelf system that I'm giving to my family to use and I can't for the life of me get the thing to work right.. I don't have another Windows PC in this house so I've been trying to use my Mac to format NTFS as I've explained and maybe that's fudging something up.
APOLOGIES for the boring explanation but I thought it best to give you the whole picture!
Can anybody help please?
thank you!!
EDIT: As a last attempt I also reformatted the drive with 1 partition, NTFS, and chose Master Boot Record in the disk utility options. Still nothing. :'(
thank you!!EDIT: As a last attempt I also reformatted the drive with 1 partition, NTFS, and chose Master Boot Record in the disk utility options. Still nothing. :'(
