semi-pro waster said:
Something like this would probably do, I was going to go for the Antec Aria but it/the replacement is out of stock. The motherboard probably isn't great for overclocking but then no mATX motherboard ever is.
Thanks for this, with your recomendations I've started to investigate each part.
CP-135-IN Intel Core 2 DUO E6300 "LGA775 Allendale" 1.86GHz (1066FSB) - OEM (CP-135-IN)
£107.99 £107.99
for overclocking I'd like to find out how far I can safely push the E6300, E6400 & E6600 and compare these results.
Will the 4mb cache give a significant benifit? I'll look for a comparison on the web somewhere....
MB-004-AK Asrock Conroe945G-DVI (Socket 775) PCI-Express DDR2 Motherboard (MB-004-AK)
£45.99 £45.99
This looks like it overclocks with room for GFX, TV & wifi cards and should be ideal, is it capable of running all current core 2's?
Any other overclockable options for comparison?
MY-034-GL GeIL 2GB (2x1GB) PC5300 667MHz Value DDR2 Dual Channel Kit (GX22GB5300DC) (MY-034-GL)
£139.99 £139.99
without any knowledge of core 2 mobo/cpus, is 667Mhz enough?
HS-017-AR Arctic Cooling Freezer 7 Pro CPU Cooler (Socket 775) (HS-017-AR)
£17.99 £17.99
looks tall, I assume it'll fit matx cases
CA-060-AN Antec Fusion HTPC Case - 430HE Watt PSU (CA-060-AN)
£97.99 £97.99
This is a bit expensive and looks big for an mATX case, it seems cooled well. The case doesn't need to integrate with a hifi but if it is otherwise a good case it doesnt matter.
I can wait for the Aria and there are similar sized cases out there aswell.
What PSU performance do I need, if I wait for the aria, will 300W be enough?
HD-085-SE Seagate Barracuda 7200.10 200GB ST3200820AS SATA-II 8MB Cache - OEM (HD-085-SE)
£45.95 £45.95
this doesn't seem to be on storage review yet, I'll investigate.
SR rates these highly:
Hitachi Deskstar T7K500 NCQ 320GB
Western Digital Raptor 74GB WD740ADFD
will be for swap disk, running windows, programs etc and I'll store elsewhere.
CD-045-NE NEC AD7170A 18x18 DVD±RW Dual Layer ReWriter (Silver) - OEM (CD-045-NE)
£19.95 £19.95
sounds good. easy to make region free?
GX-025-BG BFG 3DFuzion GeForce 7600 GT 256MB GDDR3 TV-Out/DVI (PCI-Express) - Retail (GX-025-BG)
£74.99 £74.99
looks like good value, not sure what I should be looking for with 2d graphics
Subtotal £550.84
Shipping (City Link Parcel Next Day (Delivered Mon-Fri)) £9.95
VAT £98.14
Total £658.93
Total price is about right, I don't mind spending a little more
