Please help spec my new build for £750
Hi all,
My current computer (Barton 2500 @ 3000, 1gb PC3200, Radeon 9600) is now over 4 years old and I have some money for an upgrade!
I'm a bit out of date on what is good and not. My budget is up to £750 and does not include a monitor. I'm happy to do a mild amount of overclocking.
CPU
I know that the Core2 is meant to be better than the AMD X2. I think for the moment that it's better to get faster clocked dual core than a slower clocked quad. With that in mind, I was looking at the X2 6000 (3GHz) or the Core2 E6750, both for around £100. Any thoughts? What are the overclocking prospects?
Motherboard
I have no idea what motherboards are good. I'd like sound built in, but not too fussed about anything else, including SLI (too expensive?).
Graphics
I think nVidia is ahead of the curve at the moment, and was looking at the Gainward Bliss GF8600 GTS / 512mb / 675MHz. Any good? Overclockable?
Memory
4gb would be nice, at whatever speed is required for the CPU, with a little in hand for a bit of overclocking.
HDDs
Planning to get 2x500GB drives, hopefully with a 32mb cache (does this make a big difference?) and possibly stripe them if it's worth it, with my current 320gb as a place where all my backups will live.
Optical
1x DVD/RW drive and 1x normal DVD drive
Case / PSU
I have an Antec at the moment and quite like it. I don't want anything too flashy, something like the Antec Sonata III is nice. Is the PSU powerful enough?
CPU cooler
No idea!
If you're bored and would like to help me spend my money I would appreciate it. Also, if anyone knows of a good 24" monitor I would be grateful of some advice on that too. I have 2x19" LCDs at the moment and am thinking of getting a 24" to put between them. HDMI would be nice. I have seen the Benq 2400W for less than £270, is it any good? The Dell is over £400.
Many thanks!
Hi all,
CPU
Motherboard
Graphics
Memory
HDDs
Optical
Case / PSU
CPU cooler
No idea!
Many thanks!
