Please Help! Startup is really not right! :/
29 Aug 2006
South London
Hi all, something is really wrong with when my PC starts up. Everything is fine until I have entered my password and pressed return. After that it takes ages to get to the desktop. There is little, intermittent hard drive activity whilst the delay takes its course. I really don't know how to go about solving this problem, I'd be very grateful if you guys could help me get to the bottom of this. My PC spec is in my sig below. I tried to post my DxDiag but it would make this message over 56000 characters long, and the forums doesn't let me :/
Thanks for your time.
edit: I found out if I tap the 'windows' key rapidly after I’ve entered my password, the desktop will show itself at the speed it should. However, if I don't then the problem still remains. A bit of an inconvenience I’m sure you'll agree :s
How fresh is the windows install? If its fairly recent oryou don't want to do a new one try this Make a new user account give it admin security so you can acess your other files. Then on startup it won't be loading up so many things as they are installed on the other profile. I've done it myself and it works. :)
Thanks for the reply, but after a bit of thought on what I've changed between the startup being ok and it not working. I arrived at the fact that I'd just installed Folding @ Home on my PC. After checking, it had turned out that I'd made a mistake on the install of the services. For some reason the PC was trying to start a service out of the directory i'd downloaded to (as opposed to where I'm running it from now) but due to the fact that there are no files in the download directory now I can only assume that that was the problem. Incidentally I used msconfig to find this out. Apologies for the false alarm ^^"
gah! my startup was fine for a couple of time and now it's just as bad as before :( The odd thing is that when the desktop does appear, programs such as AVG's update window are already there. For those who've seen it you'll be familiar with the timer on the 'ok' button. When the desktop appears, it has only about 9 seconds left of it's 30. Which means that everything is starting up behind the 'applying user setting' bit of the logon window when the system appears to be hanging. I just don't have control :( Can anyone help?
Thanks for the reply, I've had a look at the log file and I don't recognise anything that could be a causing the problem. Here's what the file looks like:
Logfile of HijackThis v1.99.1
Scan saved at 7:00:38 PM, on 2/6/2007
Platform: Windows XP SP2 (WinNT 5.01.2600)
MSIE: Internet Explorer v7.00 (7.00.5730.0011)
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\winlogon.exe
C:\WINDOWS\system32\services.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\system32\svchost.exe
C:\WINDOWS\System32\svchost.exe
C:\WINDOWS\system32\spoolsv.exe
C:\Program Files\Common Files\Acronis\Schedule2\schedul2.exe
C:\PROGRA~1\Grisoft\AVGFRE~1\avgamsvr.exe
C:\PROGRA~1\Grisoft\AVGFRE~1\avgupsvc.exe
C:\PROGRA~1\Grisoft\AVGFRE~1\avgemc.exe
C:\WINDOWS\system32\CTsvcCDA.EXE
C:\Program Files\Diskeeper Corporation\Diskeeper\DkService.exe
C:\Fold 2\Core 2\FAH504-Console.exe
C:\Fold\Core 1\FAH504-Console.exe
C:\Program Files\Common Files\Microsoft Shared\VS7DEBUG\MDM.EXE
C:\Program Files\NVIDIA Corporation\nTune\nTuneService.exe
C:\WINDOWS\system32\nvsvc32.exe
C:\Fold\Core 1\FahCore_78.exe
C:\Fold 2\Core 2\FahCore_78.exe
C:\Program Files\VMware\VMware Workstation\vmware-authd.exe
C:\Program Files\Common Files\VMware\VMware Virtual Image Editing\vmount2.exe
C:\WINDOWS\system32\vmnat.exe
C:\WINDOWS\system32\vmnetdhcp.exe
C:\Program Files\NVIDIA Corporation\NetworkAccessManager\bin\nSvcAppFlt.exe
C:\Program Files\NVIDIA Corporation\NetworkAccessManager\bin\nSvcIp.exe
C:\WINDOWS\Explorer.EXE
C:\PROGRA~1\Grisoft\AVGFRE~1\avgcc.exe
C:\WINDOWS\CTHELPER.EXE
C:\WINDOWS\system32\CTXFIHLP.EXE
C:\WINDOWS\SYSTEM32\CTXFISPI.EXE
C:\Program Files\Creative\Sound Blaster X-Fi\DVDAudio\CTDVDDET.EXE
C:\Program Files\Creative\Shared Files\Module Loader\DLLML.exe
C:\Program Files\Creative\Sound Blaster X-Fi\Volume Panel\VolPanel.exe
C:\WINDOWS\system32\nvraidservice.exe
C:\Program Files\Java\jre1.5.0_10\bin\jusched.exe
C:\Program Files\Acronis\TrueImageEnterpriseServer\TrueImageMonitor.exe
C:\Program Files\Acronis\TrueImageEnterpriseServer\TimounterMonitor.exe
C:\WINDOWS\system32\RUNDLL32.EXE
C:\Program Files\Common Files\Acronis\Schedule2\schedhlp.exe
C:\Program Files\iTunes\iTunesHelper.exe
C:\WINDOWS\system32\ctfmon.exe
C:\Program Files\Creative\MediaSource\Detector\CTDetect.exe
C:\Program Files\Microsoft ActiveSync\wcescomm.exe
C:\PROGRA~1\MI3AA1~1\rapimgr.exe
C:\WINDOWS\system32\wbem\unsecapp.exe
C:\Program Files\iPod\bin\iPodService.exe
C:\Program Files\Creative\ShareDLL\CADI\NotiMan.exe
C:\Program Files\Mozilla Firefox\firefox.exe
C:\WINDOWS\system32\rundll32.exe
C:\Documents and Settings\Aidan\My Documents\My Downloads\hijackthis\HijackThis.exe
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://go.microsoft.com/fwlink/?LinkId=69157
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = http://go.microsoft.com/fwlink/?LinkId=54896
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/fwlink/?LinkId=54896
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = http://go.microsoft.com/fwlink/?LinkId=69157
O2 - BHO: Adobe PDF Reader Link Helper - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelper.dll
O2 - BHO: SSVHelper Class - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre1.5.0_10\bin\ssv.dll
O4 - HKLM\..\Run: [AVG7_CC] C:\PROGRA~1\Grisoft\AVGFRE~1\avgcc.exe /STARTUP
O4 - HKLM\..\Run: [DiskeeperSystray] "C:\Program Files\Diskeeper Corporation\Diskeeper\DkIcon.exe"
O4 - HKLM\..\Run: [NVIDIA nTune] "C:\Program Files\NVIDIA Corporation\nTune\nTuneCmd.exe" boot "C:\Program Files\NVIDIA Corporation\nTune\Profiles\GPU OC.nsu"
O4 - HKLM\..\Run: [CTHelper] CTHELPER.EXE
O4 - HKLM\..\Run: [CTxfiHlp] CTXFIHLP.EXE
O4 - HKLM\..\Run: [NvCplDaemon] RUNDLL32.EXE C:\WINDOWS\system32\NvCpl.dll,NvStartup
O4 - HKLM\..\Run: [nwiz] nwiz.exe /install
O4 - HKLM\..\Run: [CTDVDDET] "C:\Program Files\Creative\Sound Blaster X-Fi\DVDAudio\CTDVDDET.EXE"
O4 - HKLM\..\Run: [RCSystem] "C:\Program Files\Creative\Shared Files\Module Loader\DLLML.exe" RCSystem * -Startup
O4 - HKLM\..\Run: [AudioDrvEmulator] "C:\Program Files\Creative\Shared Files\Module Loader\DLLML.exe" -1 AudioDrvEmulator "C:\Program Files\Creative\Shared Files\Module Loader\Audio Emulator\AudDrvEm.dll"
O4 - HKLM\..\Run: [VolPanel] "C:\Program Files\Creative\Sound Blaster X-Fi\Volume Panel\VolPanel.exe" /r
O4 - HKLM\..\Run: [UpdReg] C:\WINDOWS\UpdReg.EXE
O4 - HKLM\..\Run: [NVRaidService] C:\WINDOWS\system32\nvraidservice.exe
O4 - HKLM\..\Run: [SunJavaUpdateSched] "C:\Program Files\Java\jre1.5.0_10\bin\jusched.exe"
O4 - HKLM\..\Run: [Logitech Hardware Abstraction Layer] KHALMNPR.EXE
O4 - HKLM\..\Run: [TrueImageMonitor.exe] C:\Program Files\Acronis\TrueImageEnterpriseServer\TrueImageMonitor.exe
O4 - HKLM\..\Run: [AcronisTimounterMonitor] C:\Program Files\Acronis\TrueImageEnterpriseServer\TimounterMonitor.exe
O4 - HKLM\..\Run: [Acronis Scheduler2 Service] "C:\Program Files\Common Files\Acronis\Schedule2\schedhlp.exe"
O4 - HKLM\..\Run: [NvMediaCenter] RUNDLL32.EXE C:\WINDOWS\system32\NvMcTray.dll,NvTaskbarInit
O4 - HKLM\..\Run: [iTunesHelper] "C:\Program Files\iTunes\iTunesHelper.exe"
O4 - HKLM\..\Run: [NeroFilterCheck] C:\Program Files\Common Files\Ahead\Lib\NeroCheck.exe
O4 - HKCU\..\Run: [ctfmon.exe] C:\WINDOWS\system32\ctfmon.exe
O4 - HKCU\..\Run: [Creative Detector] "C:\Program Files\Creative\MediaSource\Detector\CTDetect.exe" /R
O4 - HKCU\..\Run: [H/PC Connection Agent] "C:\Program Files\Microsoft ActiveSync\wcescomm.exe"
O4 - Startup: Adobe Gamma.lnk = C:\Program Files\Common Files\Adobe\Calibration\Adobe Gamma Loader.exe
O4 - Global Startup: Adobe Reader Speed Launch.lnk = C:\Program Files\Adobe\Reader 8.0\Reader\reader_sl.exe
O4 - Global Startup: Adobe Reader Synchronizer.lnk = C:\Program Files\Adobe\Reader 8.0\Reader\AdobeCollabSync.exe
O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~1\MICROS~2\OFFICE11\EXCEL.EXE/3000
O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.5.0_10\bin\ssv.dll
O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.5.0_10\bin\ssv.dll
O9 - Extra button: Create Mobile Favorite - {2EAF5BB1-070F-11D3-9307-00C04FAE2D4F} - C:\PROGRA~1\MI3AA1~1\INetRepl.dll
O9 - Extra button: (no name) - {2EAF5BB2-070F-11D3-9307-00C04FAE2D4F} - C:\PROGRA~1\MI3AA1~1\INetRepl.dll
O9 - Extra 'Tools' menuitem: Create Mobile Favorite... - {2EAF5BB2-070F-11D3-9307-00C04FAE2D4F} - C:\PROGRA~1\MI3AA1~1\INetRepl.dll
O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MICROS~2\OFFICE11\REFIEBAR.DLL
O9 - Extra button: (no name) - {e2e2dd38-d088-4134-82b7-f2ba38496583} - %windir%\Network Diagnostic\xpnetdiag.exe (file missing)
O9 - Extra 'Tools' menuitem: @xpsp3res.dll,-20001 - {e2e2dd38-d088-4134-82b7-f2ba38496583} - %windir%\Network Diagnostic\xpnetdiag.exe (file missing)
O9 - Extra button: Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
O9 - Extra 'Tools' menuitem: Windows Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
O10 - Unknown file in Winsock LSP: c:\windows\system32\nvappfilter.dll
O11 - Options group: [INTERNATIONAL] International*
O17 - HKLM\System\CCS\Services\Tcpip\..\{F9265022-DF80-4BDF-ADB2-6D71FF641418}: NameServer = 212.67.120.148,212.67.96.129
O20 - Winlogon Notify: !SASWinLogon - C:\Program Files\SUPERAntiSpyware\SASWINLO.dll
O23 - Service: Acronis Scheduler2 Service (AcrSch2Svc) - Acronis - C:\Program Files\Common Files\Acronis\Schedule2\schedul2.exe
O23 - Service: Adobe LM Service - Adobe Systems - C:\Program Files\Common Files\Adobe Systems Shared\Service\Adobelmsvc.exe
O23 - Service: AVG7 Alert Manager Server (Avg7Alrt) - GRISOFT, s.r.o. - C:\PROGRA~1\Grisoft\AVGFRE~1\avgamsvr.exe
O23 - Service: AVG7 Update Service (Avg7UpdSvc) - GRISOFT, s.r.o. - C:\PROGRA~1\Grisoft\AVGFRE~1\avgupsvc.exe
O23 - Service: AVG E-mail Scanner (AVGEMS) - GRISOFT, s.r.o. - C:\PROGRA~1\Grisoft\AVGFRE~1\avgemc.exe
O23 - Service: Creative Service for CDROM Access - Creative Technology Ltd - C:\WINDOWS\system32\CTsvcCDA.EXE
O23 - Service: Diskeeper - Diskeeper Corporation - C:\Program Files\Diskeeper Corporation\Diskeeper\DkService.exe
O23 - Service: FAH@C:+Fold 2+Core 2+FAH504-Console.exe - Stanford University - C:\Fold 2\Core 2\FAH504-Console.exe
O23 - Service: FAH@C:+Fold+Core 1+FAH504-Console.exe - Stanford University - C:\Fold\Core 1\FAH504-Console.exe
O23 - Service: ForceWare Intelligent Application Manager (IAM) - Unknown owner - C:\Program Files\NVIDIA Corporation\NetworkAccessManager\bin\nSvcAppFlt.exe
O23 - Service: iPod Service - Apple Computer, Inc. - C:\Program Files\iPod\bin\iPodService.exe
O23 - Service: NBService - Nero AG - C:\Program Files\Nero\Nero 7\Nero BackItUp\NBService.exe
O23 - Service: ForceWare IP service (nSvcIp) - NVIDIA Corporation - C:\Program Files\NVIDIA Corporation\NetworkAccessManager\bin\nSvcIp.exe
O23 - Service: nTune Service (nTuneService) - NVIDIA - C:\Program Files\NVIDIA Corporation\nTune\nTuneService.exe
O23 - Service: NVIDIA Display Driver Service (NVSvc) - NVIDIA Corporation - C:\WINDOWS\system32\nvsvc32.exe
O23 - Service: VMware Authorization Service (VMAuthdService) - VMware, Inc. - C:\Program Files\VMware\VMware Workstation\vmware-authd.exe
O23 - Service: VMware DHCP Service (VMnetDHCP) - VMware, Inc. - C:\WINDOWS\system32\vmnetdhcp.exe
O23 - Service: VMware Virtual Mount Manager Extended (vmount2) - VMware, Inc. - C:\Program Files\Common Files\VMware\VMware Virtual Image Editing\vmount2.exe
O23 - Service: VMware NAT Service - VMware, Inc. - C:\WINDOWS\system32\vmnat.exe
Can you see anything that could be causing problems? :confused:
I'm no experxt and I don't know what a lot of those things are, you do seem to have quite a few things starting up.
I would basicly stop everything but the essentials and then if that fixes the problem start turning them back on one by one.
You do have a few missing files aswell, I would really do a quick google and take it to a forum that can take you through the Log there are some really clever guys there that can tell at an instant if something shouldn't be there.
