Hi,This problem has only arisen in the last few weeks. Until now I've never had any issues with sound playback.
It's most apparent when a file is playing in iTunes/Winamp and I'm browsing files on a separate physical hard drive, although it can happen any time, to a lesser degree. The problem seems to increase in severity as cpu activity increases, particularly when loading image thumbnails. .tif previews make it go crazy. Also if I try to play an .avi file directly from the second drive, it stutters big time, video and sound. This has never previously been an issue.
I running XP Home SP2 with a Core 2 Duo 6400 (2.13Ghz) with 2GB RAM. Primary HDD is a Raptor 36GB, second drive is a WD 80GB. The second drive has Vista Home installed but I've been using this setup for months with no problems. Could this be a problem?
Sound card is M-Audio Audiophile 2496 with the latest drivers (12/17/2007). The problem started before I updated the drivers (last week) so I don't think that's the issue.
The only other hardware changes I've made lately were to disconnect a faulty DVDR drive and install a Wacom Bamboo tablet.
I've tried removing/reinstalling iTunes and Winamp, with no effect.
I suspect the problem isn't specifically related to sound, but that this is the most noticable side effect.
So, thanks for reading
any ideas?
J
any ideas?J
