- 30 Apr 2011
Hello again
I recently posted here for help with my 1st pc build and got some great advice (thanks again!). Now my budget has increased
, so I thought it best to just start again and I would really appreciate any advice you can offer (no detail too small, I assure you!)
My requirements are to play current games smoothly on high settings and to be prepared for upcoming releases like Battlefield3 and Skyrim. I want to be set up for a few years and then to upgrade gfx cards and so on. I will also be using the pc for Corel Painter and a little bit of photoshop.
My budget is going to be around £600 for everything except the monitor although any savings on that amount would be nice.
First I looked at AMD processors because of price and because people say they are better for long term upgradeability but having looked closer I think the Intels are much more powerful and even 4-6 core phenom chips appear to be far weaker than the name suggets. Am I right in this regard?
So far Im looking at something like ---
intel i5 2500 3.3ghz processor £150ish
p67 motherboard in the region of £100 (P67 because i may well try overclocking someday whereas the H67 appears pointless)
Antec 100 case
600w psu (so i can upgrade gfx cards)
a decent but not top price card such as GFX 460 1gb
4gb ram
Over to you...
, so I thought it best to just start again and I would really appreciate any advice you can offer (no detail too small, I assure you!)My requirements are to play current games smoothly on high settings and to be prepared for upcoming releases like Battlefield3 and Skyrim. I want to be set up for a few years and then to upgrade gfx cards and so on. I will also be using the pc for Corel Painter and a little bit of photoshop.
Antec 100 case
4gb ram
Over to you...
