Please Help With A £600 Build
6 Dec 2014
Hi All,
After toying with the idea of small form pc's for a while i decided i really dont mind something slightly bigger.
Would love some help building a £600 machine mainly for Blizzard Games.
I have been thinking i3 and gtx 750ti because of the low power usage and that is something i would like to keep going forward if possible>
The only cases im interested in are the Corsair Carbide 240 & 540, but if possible the smaller case would be best.
I also need os and if would like red components / cables etc to make it look kinda nice, but only if possible.
Any help with the spec would be very much appreciated.
Budget is £600.
Thanks
Yh I'm buying that myself. Is that build low powered, because I had that in mind.
How does the 270 compare to the EVGA GTX 750 TI FTW edition?
Wouldn't i3 be better?
Sorry haven't been up to date with all this in over 10 years.
I wasn't really thinking about OC that's why I thought of an i3 since most blizzard games only utilise 2 cores anyway.
Apart from that everything seems ok. Would an SSD be possible in the build? Also I was told to go Avexir as ram over Team Vulcan?
Last questing Superflow PSU any good? Never heard of them and I was initially thinking going Corsair.
Tiny bit over budget but I do get an SSD and i3. Going to have a good look at it and. A good think and will post later.
Thanks
You might find if you look at the specs for the B85 boards that they only run upto 1600MHz RAM, so may as well get that Avexir kit.
