I currently have:
AMD Phenom II X6 Six Core 1090T Black Edition 3.20GHz (Socket AM3)
Corsair Vengeance 8GB (2x4GB) DDR3 PC3-15000C9 1866MHz Dual Channel Kit
HD5770 graphics card
BeQuiet Dark Power Pro P9 750W '80 Plus Gold' Modular Power Supply
Corsair A50 High-Performance CPU Cooler
My mobo is budget with 1xPCIE slot, and my case isn't big enough to hold my cooler.
I want to upgrade my mobo and graphics cards, I have in my basket:
Case
Cooler Master HAF X Gaming Tower Case
http://www.overclockers.co.uk/showproduct.php?prodid=CA-203-CM
2 of these
HIS ATI Radeon HD 6870 1024MB GDDR5 PCI-Express Graphics Card
http://www.overclockers.co.uk/showproduct.php?prodid=GX-040-HS
Which should yield significant performance improvements according to:
http://www.anandtech.com/bench/Product/296?vs=301
1. Is this a good choice?
2. Which mobo should I get that can physically fit the 2xHD6870
3. I've never done cross firing before, is it easy to set up?
4. Instead of getting 2xcopies of deus ex and dirt, do you think OC might be able to change them?
Thanks
Would love to order today
Case
2 of these
Thanks
