Decided to watercool my rig...still thinking about a swiftech kit but would prefer custom. Running a Lian Li A70B, 790i ultra, QX9650, Sli'd Ultras. Replaced the stock Lian Li fans with Noctua 1300rpm jobs (6 of them!), running off a Zalman fan controller. NB fan replaced with Antec spotcool. Cooling cpu with Noctua NFP12 with 2 Noctua fans in Push Pull. Happy enough with peformance and temps. Really want to watercool as it's something new for me and it's cool
Problem is I am hopeless at diy. Having said that, I picked up the Lian Li replacement top panel the other day which has 2 blowholes.
Same as this : http://www.lian-li.com/v2/en/product/product06.php?pr_index=127&cl_index=2&sc_index=10&ss_index=74
If you remove the top drive/psu bay it's possible to fit this top panel with 2 x 120mm fans, so I don't see why a Rad with 2 fans would not fit there. In fact I think it was designed with that in mind. So no mods required. As for the pump/reservoir I am thinking the XSPC dual 5.25" rad with built in pump. Again no mods needed. Just fit it.
So I am thinking
Rad
http://www.overclockers.co.uk/showproduct.php?prodid=wc-001-to&groupid=701&catid=193&subcat=1041
or is there something better available. and what fans work best ? would the 1300rpm noctuas be enough ?
pump/reservoir
http://www.overclockers.co.uk/showproduct.php?prodid=wc-011-xs&groupid=701&catid=193&subcat=1040
all integrated. so i like it. no idea if it's any good. it get's a good review here and they say to partner it with low restrction rads and blocks.
http://www.martinsliquidlab.com/xspc-dualbay-reservoirpump-review.html
(The specs also say's 1/4" thread, while the Rad is 3/8". Maybe I need a different Rad ?)
CPU Waterblock ?? No idea ?? What fixings do I need to buy with it ? What works best with the rad and pump I suggested ?
Tubing, the same....clueless. Do I get 3/8", 1/2", what brand, what clips etc..
Any help appreciated.
Problem is I am hopeless at diy. Having said that, I picked up the Lian Li replacement top panel the other day which has 2 blowholes. Same as this : http://www.lian-li.com/v2/en/product/product06.php?pr_index=127&cl_index=2&sc_index=10&ss_index=74
So I am thinking
Rad
pump/reservoir
