Please help with errors on COD Black Ops!
15 Jul 2009
Witney, Oxfordshire
My computer meets the minimum system requirements to play the game, however in multiplayer, the game often crashes and an error comes up. :(
Here are the details (from 'Windows Problem Reports and Solutions'):
Description
A problem caused this program to stop interacting with Windows.
Problem signature
Problem Event Name: AppHangB1
Application Name: BlackOpsMP.exe
Application Version: 0.0.0.0
Application Timestamp: 4cdb84f2
Hang Signature: 66a6
Hang Type: 2048
OS Version: 6.0.6000.2.0.0.768.3
Locale ID: 2057
Additional Hang Signature 1: dbc326ffb1f307b1cd7196adfb258d21
Additional Hang Signature 2: cbe5
Additional Hang Signature 3: 09e44c886af53db7d3f73148213c1a48
Additional Hang Signature 4: 66a6
Additional Hang Signature 5: dbc326ffb1f307b1cd7196adfb258d21
Additional Hang Signature 6: cbe5
Additional Hang Signature 7: 09e44c886af53db7d3f73148213c1a48
I would be very happy if someone could help me with this issue or give me advice. Thanks. :)
Update your graphics driver to the latest version, and run the DirectX updater on your install disc (or download one from Microsoft)
Try that and see if you get the same crashing.
Thanks for your help. :)
Is >this< what you mean by 'DirectX updater'? If not, then please can you post a link to the 'DirectX updater' you are talking about?
BlackOpsMP.exe has stopped working – Checklist
Tip: When you change anything, always remember to reboot. This might take some time, but a restart is often necessary!
1. Revalidate your files via Steam
2. Re-install Call of Duty Black Ops + Reboot
3. Upgrade DirectX
4. Check your Catalyst version . Is it 10.10? If not, update to the latest Catalyst version.
5. Check your NVIDIA driver version and update to the latest drivers version.
6. Still not working? You still get BlackOpsMP.exe has stopped working? Try to downgrade your graphic card drivers (after installing and trying the latest version of course), this seems to help in *some* cases.
We will try to find some other solution how to fix the BlackOpsMP.exe has stopped working error. If you already know a solution or if you also had this problem and fixed it, please let us know below.
Source: http://windows7themes.net/blackopsmp-exe-has-stopped-working.html
Might help.
EDIT: and from comments on that link:
or you could go here: \Steam\steamapps\common\call of duty black ops\Redist\DirectX and run DXSETUP.exe
If I reinstall Black Ops, does that mean I will have to do the campaign again and start online from level 1 again?
EDIT: Also, I don't think I have 'Catalyst'. I'm not using an ATI gfx card.
