I am currently running my Q6600 @ 3.550ghz, ram on a divider @1066mhz (OCZ 2x2gb PC2 8500).
Both Orthos. Prime95 and IBT passed over 30 mins testing, so far without error. FSB 444, multi x8.
I can also boot into windows @ 3.6ghz, ram @ 800mhz... and again, Orthos, Prime95 and IBT pass the same tests.
However, @3.6ghz settings above, If I try to set my ram above 800mhz using dividers, the mobo won't post.
I have the correct timing in the bios, I know the ram will run @1066mhz as it does so with FSB @444, multi x8???
My only reason for trying to get the ram running higher, is that after running Wprime @3.550ghz / 1066mhz, 32m test took 12.227 sec..
@3.6ghz / 800mhz it takes over 45 sec
Any ideas?
Any ideas?
