I am trying to get my PC stable with my Q6600 @ 3.6 (450 x 8), and ram @ 1128mhz 5-5-5-15-2T.
I bought this cpu 2nd hand because it can do 3.6ghz (450 x 8) @ 1.3375 vcore, 100.23% special add, vdroop: disabled; in a DFI X48 UT. I have had my ram at 1175mhz @ 5-5-5-15-2T before, but I have having problems getting them stable together.
With the current settings below, it will last 1 minute on OCCT before the PC locks up. The max temperature any CPU core reached was 63C. My chipset temps are fine. The AS5 still need time to cure and my water cooling loop still needs to settle, so I think temps will reduce over time.
My Specs:
Mobo: DFI LP X48 LT T2R | Bios 08/29 | XSPC Delta Chipset
CPU: Intel Q6600 G0 | Swiftech GTZ
Ram: OCZ PC2-9200 4GB (2 x 2GB) Flex II
GC: Asus 8800GT 512mb | Glacier Fan @ 700/1750/2000
SC: X-Fi Xtreme Gamer Fatal1ty Professional
HD's: WD 150GB Raptor & 4 x 250GB WD SE16 (Raid 0) & Seagate 7200.11 1TB
Optical Drives: 2 x NEC DVD Writers
PSU: SilverPower 600w
Case: NZXT Tempest
Cooling: Custom Water Cooling
OS: Windows XP Professional SP3
Bios Settings:
These settings:
DRAM CLK Driving Strength: Level 6
DRAM Data Driving Strength: Level 8
Ch1 DLL Default Skew Model: Model 0
Ch2 DLL Default Skew Model: Model 0
Fine Delay Step Degree: 5ps
popped up when I updated the bios to 08/29 and I have no idea what to set them at (I never changed them) and how they effect the overclock.
Please can you help, I would love to get my PC stable at these speeds!
My Specs:
Case: NZXT Tempest
Bios Settings:
Code:
CPU Feature
- Thermal Management Control: Disabled
- PPM(EIST) Mode: Disabled
- Limit CPUID MaxVal: Disabled
- CIE Function: Disabled
- Execute Disable Bit: Disabled
- Virtualization Technology: Disabled
- Core Multi-Processing: Enabled
Exist Setup Shutdown: Mode 2
Shutdown after AC Loss: Disabled
CLOCK VC0 divider: AUTO
CPU Clock Ratio Unlock
CPU Clock Ratio: 8x
- Target CPU Clock: 3600
CPU Clock: 450
Boot Up Clock: AUTO
DRAM Speed: 266/667
- Target DRAM Speed: 1128
PCIE Clock: 100mhz
PCIE Slot Config: 1X 1X
CPU Spread Spectrum: Disabled
PCIE Spread Spectrum: Disabled
SATA Spread Spectrum: Disabled
Voltage Settings
CPU VID Control: 1.3375v
CPU VID Special Add Limit: Enabled
CPU VID Special Add: 100.23%
DRAM Voltage Control: 2.12v
SB Core/CPU PLL Voltage: 1.510v
NB Core Voltage: 1.555v
CPU VTT Voltage: 1.310v
Vcore Droop Control: Disabled
Clockgen Voltage Control: 3.45v
GTL+ Buffers Strength: Strong
Host Slew Rate: Weak
GTL REF Voltage Control: Disable
x CPU GTL1/3 REF Volt: 113 (Greyed Out)
x CPU GTL 0/2 REF Volt: 100 (Greyed Out)
x North Bridge GTL REF Volt: 100 (Greyed Out)
DRAM Timing
- Enhance Data transmitting: FAST
- Enhance Addressing: FAST
- T2 Dispatch: Auto
Clock Setting Fine Delay
Ch1 Clock Crossing Setting: Auto
- DIMM 1 Clock fine delay: Current
- DIMM 2 Clock fine delay: Current
- DIMM 1 Control fine delay: Current
- DIMM 2 Control fine delay: Current
- Ch 1 Command fine delay: Current
Ch2 Clock Crossing Setting: Auto
- DIMM 3 Clock fine delay: Current
- DIMM 4 Clock fine delay: Current
- DIMM 3 Control fine delay: Current
- DIMM 4 Control fine delay: Current
- Ch 2 Command fine delay: Current
Ch1Ch2 CommonClock Setting: Auto
Ch1 RDCAS GNT-Chip Delay: Auto
Ch1 WRCAS GNT-Chip Delay: Auto
Ch1 Command to CS Delay: Auto
Ch2 RDCAS GNT-Chip Delay: Auto
Ch2 WRCAS GNT-Chip Delay: Auto
Ch2 Command to CS Delay: Auto
CAS Latency Time (tCL): 5
RAS# to CAS# Delay (tRCD): 5
RAS# Precharge (tRP): 5
Precharge Delay (tRAS): 15
All Precharge to Act: 6
REF to ACT Delay (tRFC): 52
Performance LVL (Read Delay) (tRD): 7
Read delay phase adjust: Enter
Ch1 Read delay phase (4~0)
- Channel 1 Phase 0 Pull-In: AUTO (7)
- Channel 1 Phase 1 Pull-In: AUTO (7)
- Channel 1 Phase 2 Pull-In: AUTO (7)
- Channel 1 Phase 3 Pull-In: AUTO (7)
- Channel 1 Phase 4 Pull-In: AUTO (7)
Ch2 Read delay phase (4~0)
- Channel 2 Phase 0 Pull-In: Auto (7)
- Channel 2 Phase 1 Pull-In: Auto (7)
- Channel 2 Phase 2 Pull-In: Auto (7)
- Channel 2 Phase 3 Pull-In: Auto (7)
- Channel 2 Phase 4 Pull-In: Auto (7)
MCH ODT Latency: 1
Write to PRE Delay (tWR): AUTO
Rank Write to Read (tWTR): AUTO
ACT to ACT Delay (tRRD): AUTO
Read to Write Delay (tRDWR): AUTO
Ranks Write to Write (tWRWR): AUTO
Ranks Read to Read (tRDRD): AUTO
Ranks Write to Read (tWRRD): AUTO
Read CAS# Precharge (tRTP): AUTO
ALL PRE to Refresh: AUTO
These settings:
