- 20 Jun 2013
- England, Kent
Hi All,
Firstly I am not sure where this thread needs to be posted so if it is in the wrong area then please can you move it.
I have recently purchased the following components for my PC and put this all together on Saturday.
1 x Intel Core i5-4670K 3.40GHz (Haswell) Socket LGA1150 Processor - OEM with FREE Grid 2 PC Game £187.99
1 x Asus GeForce GTX 660 DirectCU II OC 2048MB GDDR5 PCI-Express Graphics Card £199.99
1 x Gigabyte Z87-D3HP Intel Z87 (Socket 1150) DDR3 ATX Motherboard £109.99
1 x NZXT Phantom Enthusiast USB3.0 Full Tower Case - Black £104.99
1 x Samsung 120GB SSD 840 SATA 6Gb/s Basic - (MZ-7TD120BW) £77.99
1 x Microsoft Windows 8 64-Bit DVD - OEM (WN7-00403) £72
1 x Corsair Hydro H60 V2 High Performance Liquid CPU Cooler (Socket LGA2011 / 1150 / 1366 / 1155 / 1156 / AM2 / AM3) £59.99
1 x Seagate Barracuda 7200RPM 1TB SATA 6Gb/s 64MB Cache - OEM (ST1000DM003) HDD £49.99
1 x Thermaltake Smart Series 530w Modular '80Plus Bronze' Power Supply £49.99
1 x Crucial Ballistix Sport 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit £39.99
1 x OcUK 20x DVD±RW SATA ReWriter (Black) - OEM £11.99
I have had so many issues with the installation of Windows 8 it is unreal which is why I need some advice.
I installed Windows 8 onto my SSD but this was after around 10 reformat/partions and installation as every time it would come up with a new error such as missing HAL or missing NTLDR files. After the 100th time of trying to re install it without 1 error pop up it worked but now all my PC is doing is crashing randomly and going into repair.
The main question is as there are so many different errors with the installation of Windows 8 would you say I have been provided with a dodgey installation DVD or it is an error with the SSD or some other component.
This is the first build I have done so I would not put it past me that I may have done something wrong. Does anyone know if there is a service where I can send the PC back to be looked at and I pay for them to build the PC correctly and install the OS correctly for me.
Thank you very much!
Zak
Zak
