- 13 Nov 2012
- Munich
I would also suggest, when you install the driver again to go the custom way and only install the GPU and PhysX driver and skip all other drivers till your system is stable. By default the backplates barely lower GPU temps but if you tune them a little bit with more thermal pads at the backsite of the GPU that it will make a little bit preasure from the backsite of the GPU that it will get pressed better to the cooler it can help lower temps massive, if this is the issue then it could help. At the EVGA Youtube chanel you can also find some tutorial vids about precision, there is also a thread here at ocuk where someone did a very good explanation about precision and the different settings...
