Please help with RSPRO itx 3D Printer
17 Mar 2021
Hi,
First time 3D Printer user and I just purchased the RSPRO itx printer but not via thier site. I am having trouble printing and its appearing to be the settings. The bed isnt close enough to the nozzle even though it starts off that way and therefore nothing is being printed. That is now the problem so if anyone can PLEASE help me with this. Ive been playing around with this printer trying to get it working for over 3 weeks now and as much as I want to throw it out the window, it cost AUS$1200.00 so Im sort of stuck with it for now.
Any help or advice would be greatly appreciated. I have tried contacting RSPRO with no luck as they want account details etc which I dont have not being the original purchaser. The last owner hardly used it due to not being able to figure it out. So perhaps a challenge out there for all of you 3D printing experts to help a useless and nearly brain deal Aussie print on her 3D printer.
Thanks in advance.
In the manual what does it say about bed leveling?
At that price it should have auto bed level.
The manual is online version says to move the head to all four corners and adjust manually until you can’t get a piece of paper between the nozzle and bed and do the same for the centre of the bed. Did that but now it’s not printing but instead jumping layers. Other times, it’s printing away but when you check the nozzle isn’t touching the bed and no filament is coming out. Absolute nightmare...
Other then sending it back.
I would see if all the nuts\bolts are tight and you extruder is not lose.
If you have a removeable bed, make sure there is no play up\down\left\right.
If it has eccentric nuts then follow this
