Please help with sata power to molex
18 Mar 2004
u.k
Hi, Im not sure this is the right place to post but I need help regarding a project.
I am wanting to take a sata power feed Male and convert it to molex as follows..
Sata male power lead from psu -> female sata / female molex adaptor then to a male to female extension cable which will go into a sunbeam fan controller for powering 6 fans that has a male molex.
can this be done? I have seen female to male molex convertors but can i plug the male psu sata power lead into this and so on?
Thanks
Daz
Bump anyone? :confused:
The reason for needing a adaptor is that the dell machine only has sata power and no molex and I would like to power the external fans from the psu.
Edit: oops :p
Electrically I don't think there's a problem, but I suppose it depends how much power the fan controller draws as SATA probably isn't specced to provide as much power as molex.
Sata power feed ( yellow/black/red/black/orange) is the same as a molex, you just omit the 5th wire ( Orange ) and connect a molex fitting to the end.
Simple bit of soldering.
Or,
Google ' SATA to Molex Power Adapter '
This adapter changes the new SATA power connector back to the older Molex connector found on IDE Hard Drives and Optical Drives.
About £3.50
